Easy hands-on install of new foam bumpstops January 14, 2008 By:
Dan Spalinger/Team Xterra Racing
Enhanced Vehicle Suspension bumpstops from Daystar are designed to be installed on the shaft of ANY shock, enhancing its performance, softening compression and preventing hard impacts.
Bilstein OE replacement shocks for your Chevy October 9, 2007 By:
Jaime Hernandez
Check out our helpful "How to" guide on our writer's own Chevy Tahoe using Bilstein Shocks!
Lorenz Industries Bilstein 5100 Suspension System October 1, 2007 By:
Dean Waters
As we roll over 25,000 miles on our Dodge Ram 3500 Mega Cab, most of it hauling or towing, we have finally chosen our suspension system. After much research and feedback from other Ram owners we have turned to Lorenz Industries.
June 6, 2007 By:
Manny MacMillan
"Crazy mad flex!...the best $300 mod any H3 driver could ever make."
Installing Superlift's 6" Suspension System June 1, 2007 By:
Jarred Meyer
After our trip to Flat Nasty about a month ago we determined that installing a body lift and forcing the largest tires possible did not provide satisfactory ground clearance. For obvious reasons it appeared that we were in serious need of a suspension lift.
Installing a Body Lift on our 1993 Chevy K1500 March 1, 2007 By:
Jarred Meyer
In this our most recent modification we are dealing with the issue of wheel well clearance. After looking at a few different possibilities we determined that for the size tire we will be trying to fit (either a 33 or 35” tire) it would be most cost-effective to purchase a 3" body lift.
King Coil-overs Install on Ford F-150 March 1, 2007 By:
Craig Perronne
Suspension upgrades usually conjure up nightmares of an assortment of A-arms, brackets and spindles along with plenty of cutting and welding. After enough busted knuckles, burnt flesh, cursing and sweat, the new suspension is in place and finally ready for use. However one is usually broke from buying the suspension and too tired from the install to use it.
Ford F-350 Super Duty gets a lift November 1, 2006 By:
Jaime Hernández
With desert season just around the corner, Rick knew it was time to get his Ford Super Duty ready to tow in style. He wanted to give his F-350 a lift so he could fit bigger tires and give it an aggressive look. The tricky part was to keep O.E. handling, and have it be able to tow
Welding in our Long Travel Suspension Kit August 1, 2006 By:
Dean Waters
In Part III we bring in an expert to help us weld in our Total Chaos long travel suspension kit. Our Toyota Pickup is starting to look more like a REAL prerunner.......
